Edvs
With information obtained primarily from this forum, my new setup consists of a 2cuft softener with Fleck 5810 valve configured with the 1.25" turbine meter (61919) , and xtr2 controller (firmware version 1.7.1812). Since install, I have noticed erratic water usage indicated by the controller. The indicated water usage is much higher than actual water usage. I have two Class 2 water flow meters connected in series prior to the softener. One measures in cubic feet with approximately 1 oz resolution (three decimal places), and the other measures in cubic meters with approximately 3.4 oz resolution (four decimal places). I have a magnetometer with which I can monitor rotation of the turbine meter. I performed some testing:
Notes: All differences are shown in gallons. Both meters read high at a low flow .154 g/min, and softener does not read at all (expected). I observed the softener reading jump from 441 to 447 almost immediately as the water flow started (definitely not expected). The cu ft meter reads about 2.3% low, and the cu m meter reads about 3.75% low. These are both outside the 2% maximum error allowed for a Class 2 meter, or maybe my 5-gallon bucket is a bit short.
From these numbers we can clearly see that the xtr2 controller miscalculates the gallon total. The two meters are within 2% of each other, but the softener is off by huge amounts. It is not consistent in the inaccuracy. In particular, I think the softener miscalculates as water flow is started, and maybe as flow is stopped.
With the magnetometer, I can see the meter rotation, 220 magnetic flux cycles to fill the 5 gallon bucket. That would be about 44 pulses per gallon, not 80 as mention elsewhere on this forum. A value of 45.2 would approximately match the meter average accuracy. While experimenting with start/stop water flow, I noticed via the magnetometer that sometimes the meter will get stuck and not rotate again until a "highish" flow exists for more than a second or so. I did not notice any other anomalies with the magnetometer.
A couple of days ago, I changed the controller meter configuration to Generic, with 45.2 pulses per gallon. Gallon usage readings taken just now:
Quite a difference! I do not know what the controller is doing, but the behavior is certainly different between the "1.25 Turbine" and "Generic" settings, with "Generic" appearing to be much more accurate.
Monitoring continues....
Code:
cu ft meter cu m meter Softener
Reading Difference Reading Difference Reading Difference
33095.535 11.9218 382
Ran 5 gallons at 0.154 g/min:
33096.248 5.33 11.9424 5.44 382 0
Ran 5 gallons at 0.44 g/min:
33096.904 4.907 11.9607 4.83 387 5
Ran 5 gallons at 2.22 g/min:
33097.554 4.86 11.9788 4.78 391 4
Ran 5 gallons at 1.01 g/min:
33098.210 4.91 11.9970 4.81 398 7
Ran 5 gallons at 1.76 g/min:
33098.860 4.86 12.0153 4.83 407 9
Ran 5+ gallons at 2.95 g/min (overflowed my bucket):
33099.536 5.057 12.0340 4.94 416 9
Ran some at 2.03 g/min:
33100.806 9.500 12.0693 9.325 431 15
Ran some at 4.4 g/min:
33102.169 10.196 12.1072 10.012 441 10
33102.550 2.850 12.1177 2.774 449 8
Ran faucet on/off 10 times:
33102.631 0.606 12.1200 0.608 453 4
Reading a few minutes ago:
33112.219 71.72 12.3870 70.5 563 110
Start to end: 124.805 122.893 181
Code:
cu ft meter: 318.49 cu m meter: 314.07 softener: 316
