Hello,
I bought a 2.5 cubic ft acid neutralizer (non back washing) and a 48,000 grain softer with a Fleck 5600 sxt head. I have scoured tons of forms and need some advice on the settings for this. It is working but I think I can get better salt efficiency from it.
Here is some info:
Hardness from the well is low about 2-5gpg and acid is typically 6.7 or lower (constant blue stains in the house)
I checked the water hardness after the neutralizer and it was average 7-10 (and yes the PH was neutral). I think this number will change through the year as we occasionally get yellow water after very heavy rain. How yellow? No joke if you flush the toilet, it looks like someone urinated and didn't flush. When this happens it takes about 2 weeks for the water to slowly return clear. The rest of the year the water is beautifully clear and a TDS meter only shows a reading of 20 or less.
We have a shallow well at 30'.
The entire system is 1" and plumbed with 1" lines
The brine line is 1.5gpm and says 1.5lbs salt/min
The main settings I have questions about are:
BW = 7 ; Backwash (minutes)
Bd = 60 ; Brine draw minutes
RR = 7 ; Rapid Rinse minutes
BF = 7 ; Brine fill minutes
FM = t0.7
There is a ton of discussion of the lbs. of salt for the system and from what I can understand the lbs. of salt used is determined by the brine fill time not the Brine draw time ..... correct? I chose 7 for the BF because that seems to be consistent with people that have a 48,000 grain system like me.
Also the flow meter - every manual I can find says to set this to t0.7 BUT from my researching this is for the 3/4" turbine. I have a 1" system and yes it is a turbine, but how do I know if it is a 1" turbine or a 3/4"? Logic says because the system is 1" that would be the size but is there a way to verify?
Here is some info:
FM = t0.7
