imadunatic
Any ideas? Installed the system 2 weeks ago, seemed to be ok and this morning we woke to salty service water (which was the reason I replaced the 15 year old kinetico, it required constant cleaning otherwise you would have brine in the service water every time it regen'd).
My investigation revealed about 16" of water in the brine tank so I dumped it out and cycled through each phase to determine what was going on, to my amazement it started filling the brine tank as soon as it started the RR cycle and continued to fill it during the BF phase which meant essentially 16 minutes of BF, and the rapid rinse actually routing to the brine tank, not to the resin bed.
Any ideas? I have contacted the seller, but I see a ton of experience with this valve on this forum (the reason I bought it actually) and I'm hoping someone has an idea. My technical level is about as high as it gets, so tearing into this (and getting it back together correctly) is no problem.
The picture I attached is the tank after the RR cycle before the BF even starts, definitely an issue!
Thanks for any and all help.
Kevin
Kevin
