Kenton Squires
About 5 years ago I had a Fleck 5600sxt 48K grain water softener installed (replaced a 13 year old Culligan) by a plumber. Not too long ago (a couple months?) I noticed our water was hard. I checked the brine tank and noticed what I would assume is plenty of salt - it was maybe 2-3" BELOW the water line (guess I slacked on keeping it stocked with salt), but there was still a good amount of salt in the tank (at least I think it was enough salt). I went ahead and filled it with salt so the water line was not visible (salt was probably a good 4-5" above the water line - I use 50lb bags of salt) I also reviewed the settings and noticed some were not set to the manufacturer's suggestions so I did that except setting it for 32K grain - seems it may be an overkill system for my family at 48K as the regen cycle is pushing 10-14 days if I set it to 48K. After doing that I forced a regen cycle and water seemed to be soft again. I do test the water with the Hatch 5B test kit from time to time, and it's usually 0-1. However, I've noticed some consistency with water hardness slowing increasing if the A) the salt falls below the water line right after a regen cycle or B) if the unit regens when salt is below (or right at) the water line
I guess I'm here to ask 2 questions
1) should the water softener not function at 100% if the salt level is at or falls below the water level during a regen cycle?
2) for the Fleck 5600sxt 48K grain are the manufacturer's suggested settings adequate or are there better settings to use?
I've read a few other posts that mention the BLFC? Mine has a hand-written label indicating 2.4 if that makes any difference.
