Flare 3/4 inch copper
Geo422
Cin oh
I need to flare a 3/4 inch water supply pipe . I purchased a flaring set with 3/4 inch. But it seems too small.
Is there a specific size to flare 3/4 water supply line?
I got the basic pretty much down . This something I never done but now my curiosity is up on the correct size. Thank everyone George
I think flare tools and flare nut sizes refer to OD rather than nominal ID.
Is that soft tubing you are looking to flare? In that case, I think you would be looking for a 7/8.
If that is hard copper pipe, I don't know if you can flare that.
Geo422
Cin oh
Thanks it is type K water supply from city to water meter.
WorthFlorida
Solutions
Orlando, Florida
http://www.balkanplumbing.com/learn-how-to-flare-copper-water-tubing/
Type K Copper water tubing is meant for flaring
Copper tubing comes in four different types, based on its wall thickness. The 4 basic types of copper tubing are: Type K, L, M, and DWV. Type K has the thickest diameter compared to other types of copper of any given diameter. Type DWV (drain, waste, and vent) is used mainly for non-pressurized applications. The ideal type for flaring is Type K because it has a thick wall that can withstand enlargement due to flaring, and because of its soft malleable nature. Type L and M copper are meant to be soldered or brazed to join lengths of it together, as they are considered hard copper tubing. Hard copper tubing is most difficult to flare, and is expressly not meant for that purpose.
Plumber69
Prince Rupert, British Columbia
why not buy one of these fittings, converts flare to compression
Geo422
Cin oh
There are several different brands, but only one basic model.
Thank you HJ I ordered one and today I flare the copper out . Very easy to do of course with the advice from here. Now I will let you know if the water works accept it or not. George
Sylvan
Still learning
New York
"The ideal type for flaring is Type K because it has a thick wall that can withstand enlargement due to flaring, and because of its soft malleable nature."
We flair type L all the time as well as typer K and we ever double flair for higher such as AC compressors
Geo422
Cin oh
Thanks to everyone who replied. I used the hammer flare tool that HJ suggested and happy to report that water meter is in and no leaks . Can not thank you all enough. First time I have ever done a flare fitting.. GEORGE
