Mikeiii
I have an RV with a no name kitchen faucet. The RV uses 1/2" PEX plumbing. I plan to use Shark Bite fittings to Tee in an accumulator to the cold water source under the kitchen sink.
Problem:
The existing system uses an male plastic "elbow" fitting to connect to the faucet cold water supply line and I will need a straight male fitting that is Shark bite compatible. The threads on the current fitting work with 1/2" pipe thread how ever inside there is an attached rubber washer and a tapered pipe. What kind of fitting should I use?
Mike
Problem:
Mike
