Recently had to redirect sanitary sewer line for home addition. Current Sewer is 4" concrete pipe. Purchased Fernco coupling 4" concrete to 4" ABS. Now that the work is done, Fernco couplings leak at the concrete connections. I put 60 in/lbs on the clamps. Cleaned concrete (which is more like exposed aggregate due to age). I'm guessing the seal is compromised due to the concrete pipe surface. Can I use some type of sealant that won't interact negatively with the rubber to fix this leak? Thanks.
