ronstory
All--
Long time reader, first time poster. The expert on this site have been amazing and helpful. I'm doing a remodel on 2 floor ranch with a daylight basement. The floor joists are only 2x10 so I have limited drop and have planned for a 4" drop for 15 feet. What I have is two baths that are across the hall from each other the drains will be 3" ABS and drop into an existing 3" vertical stack that has a clean-out in the basement before it heads under the slab.
I think I have the design correct, with a left WC is wet vented with a fixture tee with 1.5" side ports for the lavs and 2" drain and 2" vent going up and connects to the 3" line at 45 deg and within 5ft of the toilet. The 3" drain goes down the left side of the 16" wide joist bay.
The second bathroom just has a WC and 1.5" vent connected with the 3x3x1.5 sanitee also as a 45 degs in order to line it up with the wall for the vent.
I would appreciate any feedback on the below primitive diagram and do I need a clean out on the first bathroom toilet? I'm happy to pull a toilet if it's a serious clog, that's easy. Also, I *really* don't want add a clean out since that end of the 3" line will be as high up the joist bay as a can get it... and room below is a finished room. There will be no way to open the clean out without a mess below.
All feedback is welcome.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks,
Ron
Thanks,
Ron
