RRCURbob
My 1920s era house has a bottomless clay tile sump pit liner. Because of local conditions, there is always standing water in the pit, about 24" below the floor. This means that the Zoeller pump that rests on gravel at the bottom of the pit is pretty much always partially submerged. It's positioned so that it runs anywhere from once a day to several times a day, depending on the weather.
I just acquired a plastic Wayne backup pump that runs off of a trickle-charging 12-volt battery. Instructions show the back-up pump sitting at the same level as the primary pump, with the Wayne float switch mounted above the Zoeller pump switch. Makes sense.
I'm wondering if it would be better or worse for the longevity of the Wayne pump to mount it ABOVE the Zoeller pump so that it spends most of it's life dry, or whether it would do better in the long-run for it to sit at the same elevation as the Zoeller and always be wet.
The drawback of mounting the Wayne pump higher would be that I'd need to make the water level in the pit higher in order to test it. That may be the deciding factor right there.
Other thoughts on this would be appreciated.
