hello,
my back story, built my house 12 years ago and the well worked fine till someone behind me built a house and dynamited there well, now after have a professional come in we found out that im getting 1 liter a min. So 3 weeks ago I decided to run to there dug well 425 feet from the house. had a5ft deep trench dug ran 1in 75psi csa approved piping and 2 14/2 wires new 2wire 3/4hp submersible pump 3 new check valves in the pipe length new pressure switch and 53 gallon tank bladder. switch is set at 30/50 and the tank is at 28psi. that pump is 10ft down the dug well. oh and the pump is wired 2blacks to one wire 2whites to the other and the 2 grounds to the green.
now my problem is, the system runs fine for about 3-4 cycles then the pressure drops to 0 psi, i manually lick the pressure switch on and it goes to 30psi and stops building pressure. i run to the well and fell the line and u can feel the pump humming. run back and the pressure is the same so i turn of the breaker, wait 4-5mins turn the breaker back on and the system is fine again for another 3-4 cycles.
any ideas?
any ideas?
