Drain stub out fitting and reversible p trap
Chris Redmond
Cleveland, OH
Hi all,
Novice plumber here. I moved into a new home recently, and noticed a slight odor coming from the bathroom sink, so I looked underneath and see 3 j traps fitted together (pic attached). Not sure if this is the cause, but would like to correct anyway. It looks to me like the drain stub out is too high for the sink. Would replacing with a reversing p trap correct this? Would something else work better?
If a reversing p trap would work, I was thinking I could saw through the short coupling between the downward facing 90 degree elbow and drain stub out (pic attached), use a plastic pipe fitting reamer to remove the coupling from the stub out, then replace with new (longer) coupling, adapter and finally p trap...any thoughts? Is there an easier way to do that?
Chris
Sylvan
Still learning
New York
If you bought the home and had an home inspector check it out SUE Her or him .
Document everything and hire a licensed master plumber to check the gas piping ,heating systems
If the previous owner did this type of installation and no one picked up on the code violations shame on them
I cannot imagine what dangerous conditions exist if this is in plain sight
Hopefully you know a good lawyer and can go after the previous owner
Chris Redmond
Cleveland, OH
I took a closer look at the home inspection and this is noted. The tone of your response makes me pretty concerned though.
I get that it's wrong, but am still interested if anyone else agrees with how flagrantly wrong this is, or has any other thoughts. Thanks.
Look up "pipe parana". I don't know how that would work for you.
Sylvan
Still learning
New York
Before you make any repairs or try to replace anything. Check your home inspectors report Then contact your lawyer who did the closing as in many cases money is left in escrow for this kind of shoddy workmanship
I work for over 40 law firms and it is my "expert opinion" you have a great case against the previous seller and anyone who did an inspection prior to closing
I think the simplest would be to get a trap that mates with the thing glued to the wall. From the tailpiece, put a slip 90, and meet up with what was intended to be the trap arm, but in your case will be carrying drainage from the sink before the trap.
I don't know what will fit. You would have to try.
