Drain slip joint connection
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Budrick, May 12, 2020.
  1. Budrick
    Budrick New Member
    Feb 6, 2017
    Michigan
    Hey guys can you tell me is this just a basic slip joint? It's kind of hard to see cause it's kind of grungy but it's just a chrome pipe thru the floor into the basement. Do I just unscrew that plastic/PVC nut to undo the connection similar to a sink tailpiece?
  2. Plumbs
    Plumbs In the Trades
    Oct 16, 2019
    Virginia
    That is a slip joint, so you can loosen the nut to remove the chrome piece.
  4. Budrick
    Budrick New Member
    Feb 6, 2017
    Michigan
    Thank you Plumbs
  5. Budrick
    Budrick New Member
    Feb 6, 2017
    Michigan
    Thank you Plumbs
Similar Threads: Drain slip
Plumbing Forum, Professional & DIY Advice Leaking brass slipnut at shower drain pipe, waste t connection Apr 21, 2020
Plumbing Forum, Professional & DIY Advice Kitchen drain slip joint pipe rerouting around fatter InSinkErator Aug 29, 2018
Plumbing Forum, Professional & DIY Advice Slip joint on shower drain keeps leaking! Help! Jul 14, 2011
Plumbing Forum, Professional & DIY Advice Question 752: Tub drain, plastic w/slip nuts or sch 40 glued. Apr 21, 2009
Plumbing Forum, Professional & DIY Advice Broken tub faucet drain inside wall Tuesday at 6:05 PM
