I have an installed GE dishwasher with what appears to be a clogged drain line. We've had no problems with leaks (touch wood) and the water level at the end of the cycle is at the bottom of the door. I've done the following:
1. Emptied the water, removed and cleared the trap, and used a basting syringe to get as much of the water and any debris out.
2. Run two empty cycles (hot water, no dishes or detergent) with the thinking that if we're getting debris out then we're eventually going to clear the blockage.
Other suggestions/advice on what I should try?
thanks
Guy
thanks
Guy
