JasonG
- Messages
- 14
- Reaction score
- 0
- Points
- 0
I'm doing some remodel work with CPVC and I am wondering what is the best way to connect valves in the lines.
What is your opinion on CPVC valves. I've read that CPVC valves aren't recommended so I would like to use full port brass ball valves.
Should I use two CPVC MIP fittings on both sides of the valve? I've read that I should stay away from anything CPVC and threaded.
Should I use two CPVC to brass MIP transition fittings on both sides of the valve?
Can I skip the fittings and use a brass valve with compression fittings and connect the CPVC directly to it?
