Copper dishwasher supply line?
DIYorBust
Active Member
Long Island, New York
I need to replace a copper supply line for a dishwasher, the supply stop valve is 3/8th compression. However I noticed when I went to order the soft copper tubing, the 3/8th inch OD is labeled for refrigeration, utility, or oil. Are these suitable for use in a dishwasher application, or is there another type of tubing I should order?
I'll mention that I am aware we could use a braided supply hose, but we have decided to stick with the copper supply.
DIY
DIYorBust
Active Member
Thanks Mr. Young. That seemed like it made sense, although another thread suggested that they were thinner walled than type M or L copper used for underground supplies. I guess it's good enough for a dishwasher supply.
DIYorBust
Active Member
Actually following up, I see terry said the following in 2019:
We used to hook up dishwashers with soft copper. At first I was using 1/2" OD and then later switched to 3/8" OD soft L copper.
You can really only bend copper one time without kinking it. You may get a little bend but don't count on much. Cutting back and using a new sleeve works most of the time.
It sounds like that may be 1/4" ID type L soft copper? I just checked the specs, and that would seem to have a 3/8" OD. I think the difference is that the wall would be thicker, but it would not fill the dishwasher as fast. Unfortunately, we can no longer benefit from Terry's live advice, but did I understand correctly what he was saying?
I dont know what you are asking ? 3/8 od refer tube or acr , would be equal to 1/4 inch type L Ive seen 1/2 inch od used on dishwashers as well but never used it , I used to see it (1/2 inch od) installed on older installations but they were allolder than mid 80s .
