Hopefully, my experience will help someone.
I just installed Navien's HotButton with a "12V 15A Momentary contact switch - RM11," which I picked up from eBay - https://www.ebay.com/itm/350575987090?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649.
Easy installation all around and it works great wirelessly. I purchased an additional remote (the kit comes with 2) so I have 1 in the kitchen and 1 at each bathroom.
Note than Navien's level 2 support indicated that parameter 16 (length of hot supply line) should be set to maximum, 660. Parameter 12 (time the pump is on) should be set to 5, the default value. The pump will stop when a) the water temp reaches 100 degrees OR b) the 5 minutes elapse. In my case, the pump stops after 2+- minutes after reaching 100 degrees.
