Juniper Jane
Hello there,
I am a newbie and have some questions if anyone may be able to help
I have a 625 foot well with the pump set at 605 feet.
It has a 2 HP motor with a 5 GPM pump.
The first pump died about 6 months ago and was replaced (by driller) with a new pump and motor.
The original 2HP 230Amp control box was not changed.
A couple months later the control box started acting up (capacitors/relay, the usual) so we called the drillers.
Drillers have now replaced the original control 2 HP control box with a 5 HP control box.
We noticed that there are 2 run capacitors and a gigantic start capacitor in this new 5HP box whereas the old 2 HP box had 1 run capacitor and 1 Start Capacitor and a relay of course.
Wondering why the driller would use a larger HP box with larger start and run caps - should I be concerned? I have read a lot on the internet about capacitors and have some concern the larger ones installed could eventually harm the motor. ??!!??
Ideas and input would be greatly appreciated! If I left anything out, please ask as I am a newbie to wells.
Thank you all
Thank you all
