scatkins
- Messages
- 18
- Reaction score
- 0
- Points
- 0
I'm planning for a home addition where I'm going to add one possibly two new bathrooms.
This is all single story on slab. 45 year old house. All of the underground is cast bell and hub. I've done recent remodeling and mods to the DWV in two the bathrooms and the existing DWV seems to all be in good shape.
I'm trying to develop my plans keeping in mind how the new addition will tap into the DWV.
So here is my question to those who have done major construction add-ons: How is this typically done?
I'm assuming that a major addition such as this should be "spliced" in on a relatively large diameter part of the DWV. I'm thinking of routing the DWV from the Addition (which will probably be toward the far end of the house) around the structure and splicing in somewhere between where the existing DWV exits the house and the sewer hook up.
This would seems to me to be the best chances of having all of the old and new DWV performing well.
An alternative is to find an existing toilets and modifying the DWV in that region (all to code of course). However given that everything is under slab, it seems that could be a major easter-egg hunt. I speak with a bit of experiance as I've already dug under the slab a couple of times in previous remodels. It is very time consuming work. I can only imagine what the cost would be when I use hired trades to do that kind of work.
THoughts on the issue are appreciated.
STeve
STeve
