Coleman shallow well pump
Bruce Pigeon
North Dakota
I have a Coleman shallow well pump that is leaking around the motor shaft seal in the pump housing. Can't find a replacement seal. Need help locating. Thanks
DonL
Houston, TX
Is that a re-branded Flotec ?
A model number of the pump would help.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
Yeah or just take the seal out and go to a seal and bearing store so they can match it up. Then figure out what you did to cause the failure as the pump probably got hot.
WorthFlorida
Solutions
Orlando, Florida
In ND I don't think you would have any pool and spa supply stores as there are in the southern states but those seals are fairly standard across most pumps. Any Well Supplier in your area will have it. I've replaced quite few of them on my pool pump every time I had to replaced the motor. About five times in 27 years.
