I should have done this sooner.
1. In cold areas, those without frostproof spigots put something like this over spigots during winter.
You can gather packing materials or other stuff and approximate that. If your stores had those before, they probably sold out.
2. If your kitchen sink is on an outside wall, consider opening the cabinet doors under the sink. That will let some heat into that area, and reduce the chance of freezing due to inadequate insulation.
3. You all know that running faucets at a very low dribble can prevent pipes from freezing. There is the chance that that could cause a drain line to freeze that would not have had water in it, so it could backfire. I have not heard of somebody having that problem, but I could imagine it.
Good luck, and I hope your heat stays on.
