farmboy101
Ok, I installed it and other than a few minor drips from the ball valves on my UV light prefilter all works good. I ran 1" pex from the tank Tee to the inlet and 3\4" pex from the outlet to the prefilter\UV light>house infeed. I used sharkbite fittings so I can take it all apart easily.
I am going to replace the brine float with the 2310. I will ask for a # 500 air check.
I have a 3 1\2 " brine well and salt grid setup so I hope it will fit. The supplier said it should. if not I will need a new well tube.
Also the clock will not stay programmed if I unplug it. I have checked the battery CR2032 and it reads 3.10 volts. I cant see an insulator used for shipping but the battery was installed and did not go dead.
Am I missing something??
