Circular Saw tripping GFCI outlets
AlGreen
New Jersey
I have a relatively new Skil saw (approximately a year old) that had been working fine when I plugged it into the outlet in my garage. Then I changed out this outlet to a GFCI (per code) and now the saw trips the outlet every time I turn it on. I tried it on a different outside GFCI outlet on a separate circuit and same thing. If I plug the saw into a non-GFCI outlet it works. I plan to bring the saw to a service center tomorrow. Any theories?
Three-wire plug? If so, see what the resistance is between the ground pin and the other two.
Kreemoweet
Seattle. WA
This GFCI tripping by portable electrical tools is a pretty common thing. It's likely the saw's fault if it trips multiple
GFCI's. Whenever I set up temporary power for a remodeling/construction site, with required GFCI protection, there were invariably some dudes with funky, beat-up tools that would always be tripping the devices. If it were my saw, I'd be asking for a warranty replacement.
AlGreen
New Jersey
I went to the service center this a.m. They tested the saw and said it's leaking current, causing GFCI outlets to trip. It's being fixed under warranty.
The moral to this story is that if a GFCI's test function works, and the thing trips when you run something, that device is very likely defective. I think that on brush-type motors, as they wear, the carbon dust, if it's not well designed, can create a fault path. IF a wire got pinched during assembly or the cord damaged, that could cause problems too. Some people hate the things, but while it takes a certain set of circumstances to hurt you when using an electrical device, if there's no current, there's no problem! GFCI's work.
Aaroninnh
NH
I know it wasn't the case this time, but often GFCI nuisance trips are caused by the bare ground wire touching the silver neutral screw somewhere in the circuit. It will work all day long until you add GFCI. As soon as you do it will trip when you put a load on.
Kreemoweet
Seattle. WA
This is very true, but I don't think "nuisance trip" would apply there, as it is a legitimate function of the GFCI. Nuisance trips are those that occur for no discernable reason, and when there is in fact no "legitimate" reason for the trip. Which happens all too frequently, in my experience, such as a trip occurring because an incandescent light bulb on a different circuit burned out.
BEDriedger
BC
BEDriedger
BC
Gfi's are tripped by high peak currents. Devices like Skil saws and pumps have high 'inrush currents' and 'stall currents'. They will trip the GFI's on starting. Use another circuit without GFI
