OldSalt
I'm having a problem with a check valve on my tankless hot water re-circulation line. It's evidently failing, as I have cold water in my hot water faucets/showers at the end of the run. The valve that is there is a spring-loaded-ball type (versus a swing) and is only a few months old. I've concluded that either the valve is bad, it's the wrong type of valve, or I installed it incorrectly.
Due to space constraints, I installed it vertically, with the intended flow going down, and checked flow going up. I know that swing check valves must be installed horizontally, but understood that the spring loaded type could be installed vertically. Is that correct?
The secondary issue may be water quality. I installed a whole house water filter to screen out small rock chips (i.e. like large particles of sand) in the water, which was clogging the water heater filter weekly. Those chips are still getting through, albeit at a slower rate. I intend to replace the filter with a y-strainer, as soon as Rinnai tells me the size mesh they use in their filter. It's possible that that grit is blocking the check valve as well, although it's on the opposite filtered side of the line.
Thanks for the advice, guys.
