Hi guys, great site you have here. I have searched and have a few questions that I have not found the answer for yet.
We are doing a kitchen remodel and have a sink on an exterior wall below a window. The plumbing supply lines come from the floor, the drain exits the right side of the cabinet to the corner of the kitchen. Here are a few pictures of the current cabinet. (yes, the cabinet floor is missing, damage from a previous owner).
The water filter will go away. The dishwasher and refrigerator are to the left of the sink. There will not be a corner cabinet so the area will be void. We removed soffets above the old wall cabinets and a vent line was capped so we will need to install an Air Admittance Valve in the drain line before the drain pipe enters the wall.
Since the AAV needs access and the right side of the cabinet will already have a hole for the drain, I will create a removable panel on the right side of the sink cabinet.
In an effort to not swiss-cheese the new base cabinet, here are my questions:
The water supply lines are on coming from the floor, can I change the supply line location by installing 90°s and redirect the water lines in the toe kick area to enter on the right side of the cabinet adjacent to the drain pipe? My thought was to install the shut off valves in the dead space to the right of cabinet where the removable access panel is and run flexible supply hoses to the sink as normal. Does code prevent this?
Does the dishwasher drain stack pipe need to be in the sink cabinet or can it also live in the dead space to the right of the sink cabinet, accessed by the removable panel? I found that I cannot connect to disposal, must have stackpipe: http://www.sos.state.co.us/CCR/GenerateRulePdf.do?ruleVersionId=1205
Can I run the dishwasher drain line from the dishwasher to the left, under the sink cabinet in the toe kick area and to the drain stack or disposal?
The need to eliminate as much plumbing from the sink base is caused by the cabinet we chose which is an Ikea sink drawer cabinet like this: http://www.ikea.com/us/en/catalog/products/S79040847/
Thanks for any advise and replies.
