AP1
I'm ready to caulk the base of my new toilet. I don't caulk a lot, and I always debate whether it's better to use the "wet" technique where you apply the caulk then smooth it out with a wet finger (dipping in clean water often) or use the "dry" technique where you just apply the caulk, hope you get a nice finish and leave it alone.
The "wet" technique tends to leave a smoother, rounded finish. The downside is that it takes longer.
The "dry" (don't touch it) technique has a little cleaner, tighter look because the caulk isn't spread out. However, if you don't get a perfect bead all the way around, it can leave visible flaws.
In your experience, do you recommend "wet" or "dry"?
