Hi I have a question about drains . House was built 1938 cast iron stack and floor drain in Basement concrete floor nothing is connected to the drain system since we are redoing the inside of house.
Yesterday I called a drain service company out to check the floor drain. Since water was very slow in draining.the service man used a small snake on floor drain got a bunch of junk out didn’t help much then put a scope down the toilet waste line toilet was removed . Then he went to a bigger snake and pulled out a bath towel ( I was there and saw the towel)
Then he scope the drain line again and all I could see was what he called scale laying on bottom of drain. Said it was as clean as he could get it and if I wanted then scale and small stuff out then he suggested water jetting.
The floor drain is made of cast iron and was still draining slow but a lot better.
Service guy said if I wanted a better floor drain then I had to replace the cast iron one.
My question Is water Jetting a good ideal? And why would the cast iron floor drain be so slow when main drain is open?
And would replacing it with a new drain help?
Sorry about been so curious and thanks everyone for all advice and input!!! George Terry
