Can tub drain be fixed with a Tee saddle on cast?
bnewland
KS
I've had water in my crawlspace since I moved into this house, and found the source.
It's from the tub drain where it meets the toilet drain line, then goes to the septic tank. I attached a pic. What is the best way to fix it? Does the cast drain line need to be replaced too, or can I use something like a saddle?
bnewland
KS
Can someone advise me on the condition of the waste line where the tub drain connects? Replace or repair?
Tuttles Revenge
The best method is going to be to cut a new Combination WYE and 1/8th bend fitting into the main drain where its busted.
WorthFlorida
Solutions
Orlando, Florida
Never seen a galvanized drain pipe going into a drilled out (or a torch used to burn a hole) cast iron pipe. Looks like it was epoxied in.
It would be easy enough to replace the tub drain with PVC but the connection to the main can be a problem. A plumber with the right tools to break into the cast iron pipe and insert a wye is probably the only way. Hard to say just from pictures. The saddle could work but it would only be a patch, not a permanent fix and if you can get it in the size you need. If you ever sold the home using a saddle could be a problem on an house inspection.
bnewland
KS
Thanks for the response, Tuttles Revenge. Is it a good idea to replace the line going to the septic tank (which is only 10' or so, heading to the left in the pic of post#2)?
bnewland
KS
As it is right now, the tub drains 50% into the crawlspace, and gets sump pumped out to the field in the front of the house.
This is the time to choose a permanent solution. This waste line is only the toilet+tub+sink-->septic tank. The attached pics are the toilet. Should I replace everything cast from the second pic to the septic? What material, if so?
bnewland
KS
WorthFlorida, yeah, there aren't any building codes in my county I am told, so it doesn't surprise me that things were done funky ways. My local plumber is really busy and I try to do everything I possibly can.
I know right past the foundation it is pvc to the septic tank, but I have not dug it up yet to see how the connection from cast to pvc is done. What is usually done?
bnewland
KS
I'm going with Tuttle's Revenge suggested method, inserting a combination WYE and 1/8th bend fitting. Thanks for the advise. I'll let you know how it turns out.
Tuttles Revenge
Make sure to support the cast pipe on each side of the cut prior to cutting so the pipe doesn't move in the hubs up and down stream of the cut.
I recently was visiting a distant relative in Idaho and they had a very similar installation of a shower.. but 10x worse connection.
WorthFlorida
Solutions
Orlando, Florida
There are building codes for every state. It is the local jurisdiction determines the level code enforcement. Usually it is no less than at the county level. Incorporated cities usually will have there own engineering and permitting departments.
bnewland
KS
If I cut the 4" cast on the right side of the damage, it fits into the abs 4x4x2 comb wye 1/8" bend, right? How do you fasten the cast to the abs? (edit: would you do a short piece of 4"abs with a fernco coupler to the 4" cast?)
The other 4" side of the wye will have 4" abs out to the septic tank, replacing the last bit of cast -> pvc -> septic. The tub drain will go to the 2" side of the wye.
Does this sound correct?
Tuttles Revenge
That all is correct. Start with good cast iron. Be prepared to grind off any raised lettering. Use the transition band for CI to PL as noted. Then if you're so inclined to replace the remainder with ABS or PVC out to the septic you can. Some jurisdictions limit the use of ABS/PVC that is rated for interior use.. and only Sewer rated gasketed or solid core pvc for sewer outside the home.
bnewland
KS
I took all the cast off below the wall hung carrier. It seemed cleaner.
What should I join the ci carrier to pvc with?
Then i'll just use a 90 to 4" pvc with a combo wye then pvc out the foundation to the septic tank. The tub drain will connect to the wye.
[edit: tried to attach pics, but they did not show up. Here's external link:
https://www.amazon.com/photos/shared/oIvI9r2zSeK8q2Wv9v7ibA.6LDPOWcTym-iDgsrRpYBTF ]
Tuttles Revenge
Cast to plastic is made with a clamping adapter.. fernco, mission and other brands make them. They have specific diameters to transition from the outside diameters of each material you're working with. So a Cast X Plastic or CI X PL band Part #3000-44
You will need to know the diameters of your pipe.. If its 4" then the above example would most likely work.
BTW.. PICs don't appear to be able to be uploaded to the site. You might need to upload offsite and post a link.
I use abs because its what is localy prefered I dont know why but 36 years thats what Ive used and we dont see pvc draiage fittings in big box stores here at all. or you might concider cost differances? but other places differant states you wont even find abs So Id go with what the local places sell and use the bands to join to cast iron that tuttles suggested .
