Can I remove this drain valve?
Arizona
Mesa AZ
4 year old Westinghouse stainless tank. I'm pretty sure I installed the drain valve with teflon tape and Rector seal T +2. Obviously I didn't get it sealed correctly. Is it too late to try to remove and clean and reseal? I don't want to break anything in process or find out threads are trashed and I should have left it until dead. I was thinking soak it in wd40 or similar for a few days, but I'd love some feedback. Thanks
Breplum
Licensed plumbing contractor
San Francisco Bay Area
WD-40 is great for water displacement, but hardly good for much of anything else
Definitely looks like a leak. The method you described should’ve been fool proof. Unless you put the Teflon on in the wrong direction. Pull it and redo it it should be fine.
Arizona
Mesa AZ
Follow up.... I cranked on it just a little and it's loose. I plan on draining, cleaning, and starting from scratch with new valve. thanks
