Hightechburrito
As part of my continuing bathroom renovation, I've moved onto replacing a sink and vanity. When I pulled the old trap assembly out of the drain stubout, it was about half blocked with black sludge. I can tell it has hair in it and seems a bit sandy/gritty. The pictures show after I pulled as much out with my finger as possible. I didn't remove anything from the waste arm since I'm not planning on reusing it.
It didn't seem like the drain was running slowly before I pulled everything, but I don't use this sink much so I can't be sure. The sink I do use is right behind this one and drains fine, I can run the sink full blast and there's no backup at all, so it seems the drain is fine past the stubout for this sink.
Should I do anything here before the new vanity goes in? What's left in there is solidified a bit, can't really dislodge any more with my finger. I'm a little concerned that if I go at it with a tool it will break off and go further down the drain and clog everything up. I'm not certain, but I believe this drain goes down a vertical drain pipe that is shared with the sink on the other side, then into the main waste line shared with the toilets and shower/tub in these bathrooms.
Access wont' be terrible once the new vanity goes in, so would it be stupid to install the new vanity and see how it drains? Then use some enzyme based drain cleaner over the next few weeks and check it again?
Reading some other threads, I see comments about using Bio Clean to help with buildup. But will it help with somewhat solidified buildup? I don't think 'Bio Clean' is available in my local stores, is it basically the same as other enzyme based cleaners? I think I can get it online (2 lbs for $50, how long would that last me?), and it would probably show up before I have the vanity installed.
I've also seen in some other threads comments about liquid soaps not being helpful with drain buildup. This is the bathroom my kids use, and they can go overboard with how much soap they use. Could that be related at all?
Thanks.
Thanks.
