Bryant Induction motor racket: DIY, bearing or full unit?
a_gunslinger
Cincinnati, OH USA
Braynt inducer motor started making racket today. Just like the analogy of playing cards in the bike spokes description. Same sound/issue as here:
Search "Bryant Gas Furnace Inducer Motor Making Loud Clicking Noise" in Youtube.
Its a 320725-756 - Bryant Furnace Draft Inducer
When I press on the motor portion that sits on rubber grommets the noise stops. My questions:
Presuming I turn off gas, electric, pressure switch, and switch on board that senses gas, is this a DIY for a pretty savvy DIYer? Videos online dont look that bad.
Some suggest replacing the bearing on motor portion. but since the entire unti is only 250$ any reason not to repolace whole unit?
All thoughts and advice welcome!
Did you do that video ad on purpose?
I am not familiar with such units.
I would consider looking inside to see if there was indeed something reachable that you could pull out. Maybe remnants of a bird?
Highlander
Ontario
If it gets quiet as you press it, see if you can tighten the hex screws that hold it to the bracket (going through grommets) a bit. Vaguely remember a similar problem with a Carrier (same company in the end).
