Brand new Rinnai RSC199In making low vibrations during post-purge.
limenuke0
Seattle
Hello. I had a brand new RSC199In installed on an interior wall in my basement. During post purge, the water heater creates a low vibration that can be heard throughout the house. Because I want to have someone renting my basement out, it's important that this machine isn't too loud. I've had a navien before and don't recall hearing this sound.
The RSC199in is mounted to plywood, and the plywood is mounted to 4 studs that I've blocked up a bit. I've also called Rinnai and we've replaced the original fan (warranty), but it was still similarly bad.
I'm about to spend the $$ to have my plumber rip this water heater out and put in a Navien instead. I do worry that the Navien will do the same thing, which is the main reason I haven't had it swapped yet.
I have the tap on for the first 3-4 seconds and then I turn it off. Post purge starts immediately. Video may not have picked up the low vibration
I have the exact same problem. The low drone sound post purge is very irritating.
Did you find a solution? Did you replace the unit?
No, I did
No, no solution. Rinnai wants me to call in a plumber, foot the inspection bill myself, and then they'll pay the plumber $300 for installing the parts on a visit afterwards.
To me, this is ludicrous. I've already had the fan replaced, so I'm confused as to what the sound could possibly be. I wonder if the distance of the exhaust or something is a problem.
