TorontoTim
I had a new dedicated 15A circuit ran from my basement panel all the way up to the 2nd floor bathroom at the opposite end of the house. It was done in exterior conduit as the house is 80 years old and solid brick. No real option for pulling the line inside without major drywall repairs.
It was pulled into the ceiling of the bathroom to supply power to the to-be-installed heated floor. My electrician left 20 feet coiled up to allow it to be run to the thermostat when we got to that point.
Unfortunately my demo guy in his enthusiasm cut the spool of wire off, leaving me with only 3 feet of wire.
Wanting to avoid a hidden junction box (there is no convenient place to put one that would be accessible), I was thinking perhaps the right thing to do is to splice the wire inside the T fitting on the outside of the house and bring a longer length into the room.
It is an LB (?) fitting - a T with an access panel on it that is normally used for pulling wire. Can I splice the wire inside this fitting and be within code? It is the only way to maintain an accessible join.
There is 1 other circuit in the conduit as well, running through this T fitting to feed an exterior GFCI outlet at the roofline to be used for heated cables in my eaves.
Thoughts? Suggestions?
