adayrider
Title says it all. My new 7000 sxt bypass is 1" male and my plumbing is 3/4 pex, so what fitting would work best with as little restriction and such.
If you are in a hurry, you could drain. If you drain, it would be a good time to flush your WH at the same time.If it does work on hot water, should I drain my hot tanks or just let them purge themselves?
I don't know how the Hach works on hot water. I suspect fine, but I don't know. If you put the hot water into the bottle, it will not be hot water in 20 minutes.I can't say I'm in that big of a hurry. I take it from your response that the hatch works on hot water. I think I will test again the morning and see if I make any progress .
How do you recommend flushing?
If you already have the 1 inch NPT connector, another alternative would be to use two SharkBite SS3086FLEX24LF (corrugated)or Sharkbite U3086FLEX24LF (braided) 1 inch FIP to 3/4 Sharkbite .My new 7000 sxt bypass is 1" male and my plumbing is 3/4 pex, so what fitting would work best with as little restriction and such.
