Best Place to Buy 1PH3-15 HP Cycle Sensor ?
Bob543
Texas
Looking for best company to buy 1PH3-15 HP Cycle Sensor. Thanks for any recommendations.
Bob543
Texas
When I pull up Cycle Stop Inc. it shows the sensor for 1/3hp-2hp. Is a 3hp-15hp available from Cycle Stop Inc? I found one on eBay but prefer not to buy this product off eBay.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
Yeah sorry, we no longer make the 3-15HP Cycle Sensor. There are very few weak wells with pumps 3HP or larger. The ones mentioned might work and there are several other devices available.
Bob543
Texas
Thank you Valveman for the reply. I have been looking at different devices. I have seen some devices that have water flowing through them and switches off when the water stops flowing. Are these reliable?
Bob543
Texas
No. Flow switches are not reliable. You need something that looks at motor amps and shuts down on underload.
Thank you Valveman. Since the Cycle Sensor is not available for the 3 HP, do have a recommendation for one?
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
Really any of them like the 223 mentioned above by Littlefuse will work as long as you are not using a Cycle Stop Valve. Most of these devices look for a 25% drop in amps to shut the pump down on dry run. 25% is fine as long as you don't have a CSV. But when using a CSV the amps may drop by 50% when the CSV is working the pump at low flow and the Dry run protector will think the well is dry and shut the pump down. We made the Cycle Sensor so you could set it for 55% amp drop and it would know the difference between the CSV working and actually pumping the well dry. There are not many 3HP or larger pumps in weak or low producing wells anyway, so the larger Cycle Sensors were not very popular like the 2HP and smaller ones are. As long as the well is a good producer you can use a Cycle Stop Valve and not need the dry well protection.
Bob543
Texas
Valveman....thank you for this information.
