Best Drain Choice for a Solid Stone Shower Base (Made in Indonesia)
Eurob
master tile and stone installer
Montreal
www.houzz.com
Waterproof product , let's call it a sealer , is done on top -- water test is needed -- .
I guess you found an every 6 months job for the life span of the shower . :rolleyes:
Interesting conversation for sure ........ I would say you are a hack ......... all this time you sold ( sell ) bellow -- instead of surface -- waterproofing products :D LOL
ShowerDude
Showers
Minnesota
If i were pricing/quoting this job..... The fear factor would be the chance of breaking that beast!!!! (And my back)
JohnfrWhipple
BATHROOM DESIGN & BUILD
North Vancouver, BC
I'm getting help humping this shower pan up the stairs by the client and his father in law. Plan is to lay the shower pan on a 2"x4" and have two guys on the back side and one up front. Of course it needs to go up some stairs.
The fact that the waterproofing might be a six month option makes me glad I'm taking measures from below.
I picked up a no chaulk drain yesterday from Rona - $8.99 LOL Made in China Class baby class.
I think I'll show my clients the web site from Designer Drains for a Grill "DO OVER"
http://www.designerdrains.com
JohnfrWhipple
North Vancouver, BC
Installed the no chaulk drain yesterday with some chaulk! LOL Threw away the rubber washer and used some Kerdi Fix instead.
Time to go and coat the back side with more Ardex 8+9.....
JohnfrWhipple
North Vancouver, BC
In the end I bought four no-chaulk shower drains for this stone base installation. I choose one of the four not because the grate looks nice because it does not. In fact the grate is the worst of the four options....
I installed this drain because of four reasons. One of which you can see in this photo.
You can see one reason well. One reason partially and the other two if I rotated the strainer holder 180 degrees...
Do you know why I choose this drain?
This is the drain taken apart. From left to right we have;
  • Base Drain - ties into homes 2" shower plumbing line.
  • Rubber gasket - I threw this away
  • Strainer Holder - this has the key elements I was looking for
  • Strainer - this is going to be replaced with something shinny
JohnfrWhipple
North Vancouver, BC
Drain is in - good to go.
Shower walls are waterproofed.
Shower base is waterproofed and lapped over drain.
This was a different build. Not sure I loved the challenge but it's in and getting some tile loving today or tomorrow.
I decided to build a wider curb and top the shower base with white tile. I hope it turn out ok.
Left some ISO board inside the shower tray as protection.....
And no I'm not using Ditra again. That was nearly the last of the roll I had on hand before I made the choice to dump Schluter as a supplier. I have enough left for a tiny powder room maybe.
Tile Layout: One third running bond. Shower curb face (Hob Face - Dam Face) will run off the bottom of the drywall J bead.
ShowerDude
Showers
Minnesota
that is one unfortunate vent location !!!!!!!!!!!!! I guess they put all their $ into the indonesian base!!!!
JohnfrWhipple
North Vancouver, BC
Not the best location for the floor vent, but the fixed glass will be over that area. I'm thinking a extra long bar as a towel rack. Then the floor vent will act as a towel warmer!
lol
Can you see it? I think it will work. Counter do you see how I built the shower curb out? Grew it by a couple of inches so I can later install a framless glass fixed panel and glass door.
Door screwed to the right wall.
