Just purchased a new house and have 2 bathrooms without bathroom vents. Both are on the upper floor and I have access to the attic. I purchased a Panasonic 80 CFM fan for one bathroom (45 sq ft.). I plan on venting through the roof. The gable wall is over 20' away which is why I plan on going up. Panasonic recommends 2'-3' of straight run before going up. I plan on using 4" rigid metal duct. The straight run will be under insulation. I live in Colorado so the attic will get cold. Which brings me to my questions.
1. What type of insulation do I need to wrap the vertical section? R value?
2. The run will be less than 10' total. Is it worth using a 6" duct? Fan only has a 4" outlet but says it can do 4" or 6"
3. Is it worth spending the extra money on the vent cap to get one with a starting collar already attached? Probably not that important but figured I would ask anyway.
Thank you all for the help.
