Smellslikemoney
So... I’ve run into a problem I’ve never encountered before. Custom copper farmhouse sink with a single drain outlet. Bottom of the sink had a stamped indentation that the flange for the basket strainer should sit in (pretty standard). Except it’s stamped at 4.25”. Which I’m sure is designed for a disposal flange. However nothing else is set up for a disposal I. E. no power under sink etc. and every other basket strainer has an outer flange diameter of 4.5”. So my question is are there standard basket strainers with the smaller diameter that I haven’t been able to locate yet or is there an adapter I’m unaware of to turn a disposal flange into a normal 1.5” tailpiece???? Any help would be greatly appreciated as I’ve googled just about every combination of terms or a solution.
