Basement Rough-in Removal
GLG
Frederick, MD
I have a 3" PVC pipe (toilet rough-in-see pic) and a 2" PVC pipe sticking out from unfinished basement concrete floor for bathroom. I do not want to put a bathroom in that location. How do I get rid of those PVC pipes and concrete over? Are there plugs to glue into the pipes to make flush with the floor without concrete.
Thank you.
GLG
Jdrive
Chicago
Thank you.
GLG
You would need to use an inside PVC pipe cutter like this:
And then plug it with an end cap like this:
Then concrete over top if you want (though that is quite a permanent solution).
Tuttles Revenge
In order to make a permanent cap you need one that glues over the outside diameter of the pipe itself. Since the concrete was poured directly up to the pipe, you're going to need to chip away some of the concrete to get at least enough pipe exposed and cleaned to cut the pipe and glue a cap. Depending how you intend to finish the floor, you might need to go deep enough to get a decent amount of concrete over the top of the pipe.
Dungeoness
Georgia
Related Question: can you cap these flush so they can still be used in the future? We have them in a place we are currently using for seating and it is awkward to work around and a trip hazard. The bathroom may or may not ever be put in but we want to leave that option open. Thanks!
Tuttles Revenge
Not really. They can be installed just outside of the wall but the design of the worm drive hose clamp that tightens the cap is in line with the wall surface.. essentially a nut driver or screw driver needs to turn it and would be difficult if it were flush with the wall.
This may be a better alternative for your application.
