Ryanwj
I have a 2 yr old house that had an unfinished basement when we bought it. The basement has been plumbed (to some extent) for a bathroom underneath the slab. What I have is three stubs coming out of the slab, a 2" stub where a vanity sink would go, a 4" stub where a toilet would go and a 1-1/2" stub where a tub/shower would go. About 10' away I have a pit for a sewage ejector pump. Based on extensively searching through many posts on these forums I have managed to put together what I think is the correct way to finish the DWV piping for this setup using a group vent that tees off where the vanity sink will connect to the 2" stub. My plan is to tie that vent back into the vent for the ejector pit in the basement ceiling and then run a vertical vent up through a chase into the attic and out the roof eventually. I don't believe my house has a main vent stack as it appears there are 3 separate vents through the roof. One vent is located near the kitchen/laundry, and one each near the two existing bathrooms on the main floor. I assume this means I will have to run a new vent through the roof for the basement bath. I'd like confirmation of this.
Assuming the above is correct (I will be posting a pic below that should help anyone interested on confirm), my big question is whether I can run an additional drain from a proposed wet bar into the basement vanity drain line above the slab. I'm obviously trying to avoid busting the slab to tie in this wet bar, but I'm worried bringing it in above the slab might mess up the group vent. I assume if this was "legal" I would need to tie it in below the waste/vent tee for the vanity sink. The wet bar sink would be vented locally and said vent tied into the group vent for the bathroom that eventually will protrude through the roof. Please see the attached sketch for clarity. Any thoughts or helps is appreciated as this is my first venture into significant DWV plumbing and I'm trying to do it right. I have not found any books that address a situation close to the one I have described.
