Hi,
I have hydronic heat system at home. One zone. Boiler in basement with loop around the basement ceiling perimeter, with a set of venturis and Tees going to each baseboard upstairs and even to the 2nd floor. One baseboard unit on 2nd floor doesn't heat up. When i bleed the one bleed valve on it, water immediately comes out. So, no apparent air lock in the pipes. I'm at a loss as to what else it could be. The system has performed perfectly for years.
I suppose it's possible that some corrosion or chunk of crap may have broken off and clogged the incoming/outgoing pipe to this one unit?? Worst case scenario would be to wait for warmer temps and then de-solder both ends of the baseboard and use a wet/dry vac to make sure both pipes run free and clear. But I'm no expert at this sort of thing and would appreciate advice from more experienced folks, especially if it keeps me from doing that worst case scenario I just mentioned!
Thanks
Theodore.
Thanks
Theodore.
