- Messages
- 33,608
- Reaction score
- 1,047
- Points
- 113
- Location
- Cave Creek, Arizona
- Website
- www.terrylove.com
That venturi tee does two things. First it creates some resistance, which forces water to be diverted into the line going to the radiator. Second, and maybe most important, is that the water flowing through the venturi creates a pressure DROP after the tee which helps pull the water through the radiator. BUT, the venturi effect depends on a certain water velocity, as does the amount of resistance through the tee. If the pump does not deliver that flow, then the venturi does not operate, and very little flow will occur through the radiator.
