Mike Nadeau
Hello,
I have aquired and installed an Autotrol Readysoft system. It has a 960/255 setup.
This is a twin tank setup. It consists of 2 sides each having 2 tanks joined in the middle. 4 tanks total. I replaced all the seals that needed replacing and the turbine meter. Everything seems to work perfectly. But I don't know what 2 of the tanks consist of. That being said I have the serial numbers on the to units and have no way to get any information. I want to make sure i have the correct settings for my resin bed size. Plus getting rustyish water for a few minutes after regeneration. My test strips seem to indicate 0 hardness so i assume it works. I'm also trying to figure out how to read the display.
Example: tank 1 reads 1374 and I take a 15 minute shower. The number only goes down a couple of digits. So is this in 5 gallon increments?
Also the injectors are grey and do not match any of the colors available?
