Any min. height for stub out required by code for kitchen and bathroom sink
Curiousv
Tacoma WA
We are in Tacoma WA
Is there any code that says there should be certain min. height required from floor to shut off valve where you put escutcheon? I think professionals call it stub out
I know std. height is 19" for drain and 22" for sink supply lines. but is it required by code ?
same question I have for bathroom supply lines stub out height ..any height required by code?
Crush62
Journey Level Plumber/State Certified Plmbg Instr
Lynnwood, Wa.
Its all subjective...There is no code out there that references stub out height for water OR waste. Too many different style of fixtures. Example...On new construction, IF you are having a top mount KS one would rough in water @ 20" & waste 18". However, knowing what type of fixtures & base cove you decide.
If you know what the fixtures you're going to use are, then, rough-in the bits where they both look good and fit. There is no industry standard that will work in every situation. For example, some faucets come with integrated hoses. Some sinks are deeper than others. Some sinks like a pedestal one will only work when things are in very precise positions. Throw in a disposer in a kitchen sink, and your waste location may not work. Decide you want a deeper sink, it won't work.
