DIYorBust
Active Member
I've encountered some of this on a project. I initially thought it was copper, but a section of pipe reads "Anaconda 85 Redbrass". The pipe is threaded and the fittings appear to be a type of brass. It's generally performing ok, although one section appears to have been repaired with a galvanized fitting, and that is leaking. The pipe appears to be generally performing well. In other areas,the pipe has been replaced by regular copper. Is there any concern with allowing this pipe to remain? Can I cut out the fitting and sweat in a section of copper, or should I try to replace the coupling with brass?
Thank you!
DIY
Thank you!
DIY
