American Standard Aquaseal, Need parts help--shower valve leaking
Crosstalk
PA
Hi everyone-
I am new to 3 valve shower valve repair and can't figure out what I have here. I have a drip from the faucet when off so I'm thinking worn washer or seat. When I took it apart, I didn't find any washers--some kind of metal-on-metal seating system. On the hot side, I was able to remove what is shown in the photos. On the cold side, only the outer ring with the hex flats came out. The rest of the valve is stuck in the body. Maybe I can yank it out, but just jiggled it a bit for now because I needed to turn the water back on. Does anyone recognize these parts? Can this be repaired? Looks like a special tool might be needed to remove the "seat" part if it's repairable.
Thank you.
Crosstalk
PA
Actually it looks like it could be the american standard aquaseal stem but it has fallen apart. How do I get it out? a pick?
Marlinman
Jacksonville Florida
It is American Standard Aquaseal. The stem assembly is 72950-17, Retainer nut is 855-17 and the seat is 862-14. The old washer and metal ring will need to be removed. A o-ring pick is probably best.
Crosstalk
PA
I replaced the stems and everything is working great. I didn't order the seats, but they don't look so great. How risky is it to try to remove the old seats? Are they going to difficult to turn out or better left alone since I don't have a drip? Looks like a 1/4" allen needed.
There is a drip coming out of the faucet when the shower is on. Is this normal or should I replace the diverter stem also?
