Well I assume this is a very old system. We use it about 6 weeks or so in the summer. When it works it works great and the only real problem is getting it started. We have a pro who comes out and winterizes the house every year. If there's a check valve it's buried. I don't see anything like that up top. Or it's hidden in the suction pipe or something and doesn't look any different than the regular pipe. We gave up on the "pros" priming the pump. They don't listen to me and I've gotten pretty good at priming "this pump". Until this year we would prime the pump and even with the power off to it for weeks at a time it never lost prime. This year it needs to be primed every visit. A lot of this I blame on this just being a really old system and probably way past it's prime. But for a vacation home I'm not really motivated to spend a lot of money getting it replaced when I can get it going in 20 minutes or so. Anyway when I show up it usually takes about 5 gallons to get it going which seems like a lot to me. But I do get it going. I just keep adding water at the top and putting my hand over the fill until I start feeling pressure. The sound changes also when it starts to catch. Once it "catches" it's fine till we shut the power off it and go home for a few weeks. I guess these are the things I'm interested in.
1. Losing prime. I assume the check valve is just getting old and it's probably down deep in the ground. If I'm going to deal with that it's probably time to just get a modern set up. Bladder tank and all that. It's probably not completely gone but starting to go as it's fine as long as we're up here and using water.
2. AVC spitting water. I checked it the next day and it's no longer spitting water. I guess it found it's balance. I realize it's not suppose to spit water lol. I was wondering why it would do that? Perhaps the float ball wasn't quite seated well yet? I haven't been able to find information on how this specific valve works. Just interested. I realize it's suppose to fill the tank with air as needed. Would be nice if there was a little instruction flyer with it
3. I dump a lot of water getting it started, like 5 gallons of water, with a gallon or two going on the ground. Seems like 5 or 6 gallons of water is a LOT to prime this little pump. But if it works it works. I guessed it must be filling the entire tank (?) or suction pipe or something, but if that is what is happening it has great pressure and doesn't short cycle. Actually it never comes on unless we use waster. The kitchen light flickers a little when it starts so that's my indicator. Whatever is happening the pump seems to find it's balance once it's running and straightens it's self out quickly. The guy that primed it the first year we got the place took like hours to get it started and was all about us getting it replaced Adding like a cup of water at a time, putting the plug back in and sitting there for 5 minutes over and over. I was getting the impression he wasn't the best and not that good with old school well worn equipment. But we stopped calling him in the spring and the pump has been basically acting this same way for the next 8 years and works awesome once I get it started. Usually about 20 minutes from start to finish.
4. This spring we had a frozen pipe and didn't realize it. I should have known as the pump came up to pressure and shut off. But I'm learning along the way. So we called the dude out. So he came out and thawed it out. Torch on the pipe kinda thing down in the well. Well while he was down the there's a stem that comes out of the front of the pump that he just kept cranking on. I kept telling him that once the pump was running it's perfectly fine but he just kept turning it and nodding. So I'm kinda concerned what that was all about. I do know he want to sell me a new set up lol.
5. So to sum up I was wondering what would cause the AVC to spit water (at least for awhile) and what the hell that guy was cranking on like crazy and if that was something maybe he was a little too aggressive on. I can see giving something a quarter turn or something when it's been pumping fine but he seemed to be going way over the top for a tweak. That was on the actual pump body on the front and not any electrical control, etc.
Well anyone that has the patience to read through all that, bless you, and has any guesses especially about #5 I'd really appreciate hearing it
Seems like a really basic system and as of the moment everything is up and working well as far as volume and pressure to the house. But I love learning about stuff. I have a feeling, in general, it's a really old pump and it's age is starting to show and normal wear is becoming an issue but I'll drag it out as long as possible. I hate replacing something that works. Bless ya all and have a great day!
