Coffer85
I plan on moving my washer and dryer out of the kitchen and put it into the closed(insulation) old garage. Theres no drain or water hook up. I don't plan on digging into the slab for the drain. I've seen other houses in my area that have used a sump to drain the water through the attic back to an area with a drain line. My question is about the sump, I found one built in a large enough unit to handle more gallons than my washer puts out, can I risk the soap in the water causing air problems with the sump draining or do I have to get a laundry sink to use between the washer and sump. Thanks!
