Nick Bethard
Hi guys,
We just moved into a home with well water. We noticed a sulfer smell periodically and also noticed that the toilets get a film built up relatively fast. Back when it was warm, we brought a jug of water to an event for the kids to play with (water toys...) and the remark was made that it looked like creek water.....
The house has a water softener that seems to be functioning fine (although I need to check and see if the backwash setting needs adjustment). I just got the water test results back and it seems we need some iron removal. Based on some looking I did (some here), it seems a Katalox light system might be in order.
I need to check my well pump's flow rate yet, but I can do that later and adjust the specific amount/size of filtration as necessary, but I'm pretty certain that our well's flow rate is pretty high.
The house also has a sterilizer light, but it needs a new bulb as the one in it is ancient.
Water test results:
Nitrate/Nitrite - <0.10 (below detection threshold of the test)
Sulfer - <1.8 (below detection threshold of the test)
Hardness - 340 mg/L
Iron - 2 mg/L
pH - 7.33
TDS - 509.6 mg/L
They also tested after the softener as a courtesy:
Hardness - 0 mg/L
Iron - <1 mg/L
pH - 7.48
TDS - 526.3 mg/L
Also, coliform test results were OK (nothing found).
I'm open to any and all sugfestions. Thanks for your help and expertise!
Nick
Water test results:
Hardness - 340 mg/L
Iron - 2 mg/L
pH - 7.33
TDS - 509.6 mg/L
Hardness - 0 mg/L
Iron - <1 mg/L
pH - 7.48
TDS - 526.3 mg/L
Nick
