This system was installed 2.5 years ago and and the installer ran the drain out into the yard which within a years time started killing the grass. another issue is that one of the tanks would sweat and eventually the floor began to weaken and the tank tilt just a little. We were also having strong surfer smell on the hot water side. So we pushed the bypass valve and unplugged the system but left the tank plumbed in.
We have since repaired the floor as well as installed a pan under the tank and also instilled an underground drain for the water softener and ;ac condensation line. We also understand that changing the anoid rod in the water heater will make a big difference,
So we would like to restart the softener. Do you think it would be okay to just let it run itself through a few cycles an then start using it?
Charrie
Charrie
