90 degree double sanitary tee (schedule 40)
Nmantas
Detroit Area
Does any company make a 90 double sanitary tee that is schedule 40 instead of DWV? I see many but they are all DWV. (I'm looking for 3" for the vertical and can make anything 1-1/2" or bigger work on the horizontals).
It wouldn't be a santee if it wasn't DWV? Order a PVC sch40 santee as appears in photo. It could be you are looking for something else
Regular tees, go to manufacture site to check but you wont find a tee configured like a santee designed for water .
Schedule 40 is a size, and not a pressure rating. Nmantas, are you looking for pressure-rated fittings, or just something mechanically stronger? What is the purpose of your search?
Nmantas
Detroit Area
Yes, I was confused if this fitting was for schedule 40 pipe.....it has been confirmed to be. Thanks for your help.
